Lowest Compression
Old Jan 15, 2006 | 10:26 PM
Dunc's Avatar
BCICAN
Default Lowest Compression
What is the minimum CR that a gasoline engine has to have? Isn't it like 7:1 or 7.5:1? I did search too haha.
Old Jan 16, 2006 | 12:26 AM
voiceinurhead05's Avatar
Default Re: Lowest Compression (Dunc)
I'm not sure of the CR, but for a honda engine the absolute minimum is anywhere from 45-65psi (depending on the engine)
Old Jan 16, 2006 | 07:38 AM
Padawan's Avatar
Darth ModerVader
Gasoline internal-combustion engines have existed with compression ratios of 2:1.
Old Jan 16, 2006 | 08:32 AM
Default Re: Lowest Compression (Padawan)
Maybe, but it wasn't a Honda.
Old Jan 16, 2006 | 09:29 AM
Padawan's Avatar
Darth ModerVader
Default Re: Lowest Compression (voiceinurhead05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by voiceinurhead05 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe, but it wasn't a Honda.</TD></TR></TABLE>
No, it wasn't, but the original poster stated "gasoline engine", not "Honda engine".
Old Jan 16, 2006 | 12:28 PM
Dunc's Avatar
BCICAN
Now, that I did not know...let me rephrase then:
My main concern is how low of a CR before a honda/acura engine does not turn? Also, is that 2:1 engine still being used today or could any engine today use something that low?
Old Jan 16, 2006 | 04:09 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">Now, that I did not know...let me rephrase then:
My main concern is how low of a CR before a honda/acura engine does not turn? Also, is that 2:1 engine still being used today or could any engine today use something that low?</TD></TR></TABLE>
My Triumph came from the factory with 7:1 compression, and it ran fine. I don't see why a Honda engine wouldn't run at that low, or a lower ratio, but you'll certainly be making less tham optimal power that way, and might not be able to make use of the entire power band. Cam profiles and rpm range are chosen with an engine's compression ratio in mind.
But seriously, there's no reason to use less than 9:1 these days. Why was this question asked?
Old Jan 16, 2006 | 04:29 PM
Dunc's Avatar
BCICAN
Default Re: Lowest Compression (TunerN00b)
Mainly because I was trying to prove and have some people realize that anything under 9:1 is overkill and not that useful......ESPECIALLY for only 400whp. 400whp is childs play now days.
smithenhiven
Classic Hondas
101
Oct 21, 2017 11:25 PM
-=M=-
Sep 30, 2005 11:48 PM
The G2 Racer
Acura TSX
Jan 14, 2004 10:07 PM
