lost motion assembly
Old Sep 6, 2005 | 09:58 AM
boost'dsiR's Avatar
Default lost motion assembly
hi would vtec engage right if the lost motion assembly is worn down or put in incorrectly ?
Old Sep 6, 2005 | 11:31 AM
tgreaves's Avatar
Default Re: lost motion assembly (boost'dsiR)
Shouldnt make too much of a difference.. How can you put a lma in wrong?
Old Sep 6, 2005 | 11:51 AM
boost'dsiR's Avatar
Default Re: lost motion assembly (tgreaves)
it was just a thought so iguess there is something else wrong wit it
Old Sep 6, 2005 | 12:20 PM
tgreaves's Avatar
Check your vtec filter..
Old Sep 6, 2005 | 12:47 PM
boost'dsiR's Avatar
its clean
Old Sep 6, 2005 | 12:52 PM
tgreaves's Avatar
Whats it doing?
Old Sep 6, 2005 | 01:23 PM
boost'dsiR's Avatar
seems like its engaging vtec but its not and power dies after 6k power dips way too much on the vtec cross over
Old Sep 6, 2005 | 07:18 PM
flatblackracing's Avatar
if you run a cat check it out it could be clogged.
also I ran into a customers car with the same problem, after hours of checking **** out it was a dirty *** intake filter....
check those out first
Old Sep 6, 2005 | 07:29 PM
krazie1's Avatar
BANNED
Default Re: lost motion assembly (flatblackracing)
it usually is the simplest ****
check air, fuel, vtec filters. Cat as mentioned. also might bew the valve adjustment. timing is off.
it could be a couple of things
hope this helps
Old Sep 6, 2005 | 08:48 PM
Mythias's Avatar
If you have a worn LMA you will hear a loud tick, similiar to the sound from incorrect valve lash adjustment. That tick sound should stop upon v-tec. In some cases, but rare, you will only hear a click/clunk upon v-tec engagement/disengagement.
Old Sep 6, 2005 | 09:13 PM
rev-speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Shouldnt make too much of a difference.. How can you put a lma in wrong?</TD></TR></TABLE>
u can put it upside down
i ran into one that took me a very long time to figure out
it the lma was upside down
so vtec will never engage
Old Sep 6, 2005 | 09:15 PM
rev-speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost’dsiR &raquo;</TD></TR><TR><TD CLASS="quote">seems like its engaging vtec but its not and power dies after 6k power dips way too much on the vtec cross over</TD></TR></TABLE>
have a dyno chart of it?
check ur basic engine performance first
Old Sep 14, 2005 | 05:39 AM
tgreaves's Avatar
Default Re: lost motion assembly (mythias)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mythias &raquo;</TD></TR><TR><TD CLASS="quote">If you have a worn LMA you will hear a loud tick, similiar to the sound from incorrect valve lash adjustment. That tick sound should stop upon v-tec. In some cases, but rare, you will only hear a click/clunk upon v-tec engagement/disengagement.</TD></TR></TABLE>
Speak of the devil.. My car started doing this last night.. Does it kinda sound like a lifter tapping in a v8 engine??
I pulled the valve cover off and pushed the vtec rocker down with a screw driver and it "clicked" back up so im assuming thats what it is..
GSR coupe
Feb 27, 2010 12:11 PM
bonstokLS
Jan 20, 2009 07:16 PM
the.hamburglar
Jul 15, 2007 04:59 PM
CDN Yellow ITR
Jul 3, 2005 02:01 PM
DC2 BoZz
Dec 8, 2004 01:14 PM
