lost motion assemblies???
Old Sep 19, 2004 | 12:21 PM
00s2KkId's Avatar
Default lost motion assemblies???
i have a 96 GSR and i did a valve adjustment then i got a tapping from the head.. i took it to a mechanic and they said i had a lifter tapping..now whats the difference between a lost motion assemby and a lifter.. where are these located in the head
Old Sep 19, 2004 | 09:36 PM
HONDA_TYPE_R's Avatar
Default Re: lost motion assemblies??? (96GSRkId)
I'd like to know this too...
Old Sep 20, 2004 | 06:36 PM
00s2KkId's Avatar
anybody?? i need reassurance.. my helm manual came in today... says nothing about lifters so im guessing a LMA is basically hondas lifter.. signing off im RON BURGANDY?!?!?
Old Sep 20, 2004 | 07:55 PM
deSigi's Avatar
The only thing I can imagine your mechanic meant by lifters is rocker arms. But if you did a valve adfustment then that should have solved that problem. I hope your mech. didn't mean push rods, because then I would suggest to go see another mechanic.
Did you do your adjustment when the engine was cold? If yes, then it might be the lca's.
Anyone else know what he might have meant by lifters?
Old Sep 20, 2004 | 09:48 PM
HEAD's Avatar
there are lifters that go under the rocker assembly. there round, two piece, and have a small spring inside. I am not sure how else to explain it. but I will say I don't usually see to many go bad-not saying that it couldn't go bad it's just not common.
Old Sep 21, 2004 | 05:10 AM
JimBlake's Avatar
Default Re: lost motion assemblies??? (HEAD)
Lifters, tappets, rockers, cam-followers; some people sorta use those terms interchangeably. Whatever goes inbetween the camshaft & the valve. Hondas use levers that you can call tappets or rockers or ??? Tapping noise under the valve cover often means you need to adjust your valve lash. On many other cars it means the hydraulic lifters/tappets are going bad...
If you did your valve adjustment wrong, that might be it. If the mechanic simply listened he's sorta guessing. Until he opens up the valve cover & actually works on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HEAD &raquo;</TD></TR><TR><TD CLASS="quote">there are lifters that go under the rocker assembly. there round, two piece, and have a small spring inside. I am not sure how else to explain it. but I will say I don't usually see to many go bad-not saying that it couldn't go bad it's just not common.</TD></TR></TABLE>Those are lost-motion assemblies. Only VTEC engines have LMAs. They're supposed to hold some tension against the VTEC cam-follower so it doesn't rattle loose when VTEC is not engaged. They can make a tapping noise, too.
Then again, Honda fuel injectors also make ticking noises...
Old Sep 21, 2004 | 02:42 PM
00s2KkId's Avatar
thanks for the info guys...probly gonna put in some new LMA's soon.. i know its not the fuel injectors.. way too loud and sounds likes its coming from the intake side of number 2 cylinder
Old Sep 21, 2004 | 06:58 PM
Runnerdown's Avatar
You say it started after you did the valve adjustment?....
Old Sep 22, 2004 | 01:40 AM
b00sted93Hatch's Avatar
Default Re: (Runnerdown)
Do another valve adjustment and check your clearances. What clearances did your do them at anyways?
Old Sep 22, 2004 | 03:39 AM
Sliced Beard's Avatar
Default Re: (allMotor93Hatch)
to save you some money, contact member Patch......I think he has an almost new set of ITR LMA's
Old Sep 22, 2004 | 05:21 PM
00s2KkId's Avatar
i did the adjustment after the car had been sitting awhile...was defintely cold and i did the intake valves at around .17 mm and exhaust at around .19 mm
Old Sep 22, 2004 | 07:11 PM
Default Re: (96GSRkId)
I'd do it again but .15 on the intake and .17 on the exhaust. Run them on the tighter side of honda clearances. Also when you measure make sure there a slight drag with feeler gauge.
OUBob
Feb 29, 2012 03:27 PM
sde780
Mar 30, 2009 03:36 PM
hazrd420
Aug 13, 2007 08:29 PM
jdm94ej1
10
Jul 12, 2007 05:18 PM
black_dc5
21
Aug 16, 2003 02:40 PM
