Losing Pressure in clutch pedal!!!
Old May 12, 2006 | 01:24 PM
RangerHatch's Avatar
Default Losing Pressure in clutch pedal!!!
Ok so i figured it out. I bleed the clutch slave cylinder.....gets presser back. Cars rides fine. But after a couple of gear changes and pushing in the clutch it starts to lose pressure again. I did this a few times and the same thing happens. Am i bleeding them wrong? Methods you guys use??
What i did:
-I pumped it a couple times and just let the fluid just drain untill all air bubbles were out.
-Re-tighten the bolt.
-Pump clutch again
-Let the fluid drain out
-Retighten
After that the pressure is great! But after a little bit it slowly loses pressure
Should i be doing/using a different method? Please let me know guys thanks!!
Old May 12, 2006 | 03:07 PM
SAVIOVEGA's Avatar
Default Re: Losing Pressure in clutch pedal!!! (RangerHatch)
Pump pedal, hold pedal down, loosen bolt, tighten bolt, repeat
Whenever you loosen the bolt, the pedal must be held down.
Old May 12, 2006 | 04:34 PM
Default Re: Losing Pressure in clutch pedal!!! (SAVIOVEGA)
thanks i knew it had to be something small! Thank you
scoker83
16
May 12, 2014 07:01 PM
Dukie432
Jun 23, 2009 08:05 PM
skierGT
Jul 23, 2003 12:29 PM
TEGME
Dec 3, 2002 05:25 AM
