Loose control arm?...Help please
Old Sep 10, 2001 | 10:36 PM
Brando's Avatar
Default Loose control arm?...Help please
sup guys,
my gf is trying to sell her 93 si hatch. the people want to take it to a mechanic cause it makes a rattling noise when it hits bumps. in advance the only mods it has are suspension techniques lower rear/front sway bars.
anyways, when i hit a bump when driving it sounds like a sound a roller coaster makes you know on its rail. and its coming from the left side. i cant pinpoint it. i jacked up the car, and did a quick look at all the bolts but they look fine. at first i thought it was a loose pedal, but not sure. maybe control arm. is there anyway to pinpoint it even further?
also the polyurethane bushings the sway bars come equipped with squeak like crazy on bumps is this normal? i spayed wd-40 on em once and it cured it for a bit. any other suggestions?
i dont want to spend the money to get it inspected. thanks
brandon
Old Sep 11, 2001 | 01:05 AM
court's Avatar
25 Year Member
Default Re: Loose control arm?...Help please (Brando)
you need to put more grease into the bushings
Old Sep 11, 2001 | 02:14 PM
Dusty's Avatar
New User
hey what kind of grease...whtie lithium? high temp? or what? i have similar problem. high temp doesn't seem to solve it...(all i had at teh time) but haven't diven it for long
Devildog223
Suspension & Brakes
Mar 18, 2018 09:34 AM
Littlegreend15
Jul 11, 2005 02:36 PM
92integraVTECgsr
Feb 18, 2005 01:02 PM
Brando
Sep 12, 2001 05:19 PM
