looking for wiring goorooo.....
Old Oct 8, 2005 | 04:48 PM
lastturn's Avatar
Default looking for wiring goorooo.....
yeah, my DC2 is stuck on the 'ACC' key switch mode. I must have a short some where but I cant find it. I have to disconnect the Battery to turn it off. anybody have a wiring diagram or have had this problem before??
thanks
Old Oct 10, 2005 | 07:16 PM
lastturn's Avatar
Default Re: looking for wiring goorooo..... (lastturn)
could it be the main relay??
Old Oct 11, 2005 | 12:07 AM
PaChiLa Leader's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lastturn &raquo;</TD></TR><TR><TD CLASS="quote">could it be the main relay??</TD></TR></TABLE>
i had a similiar problem but it was the other way around that it won't get in ACC
i end up buying a used ignition key switch and swap the cylinders then everything went back to normal again..
my problem starts with smoking steeringwheel colum with a short..
hope that helps
Old Oct 11, 2005 | 03:43 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lastturn &raquo;</TD></TR><TR><TD CLASS="quote">could it be the main relay??</TD></TR></TABLE>No, the main relay doesn't do anything until you turn the key to "ON".
I'll go along with PaChiLa... the electrical part of your ignition switch.
Old Oct 11, 2005 | 11:32 AM
lastturn's Avatar
Default Re: looking for wiring goorooo..... (JimBlake)
I disconnected the ingnition switch all together and it still stays on. those wires go into the fuse box under the dash and from there. i dont know where it goes.
anybody have a wiring diagram??
thanks
n.o.r.e
Oct 6, 2011 07:07 AM
DXDOHCVTEC
13
Apr 20, 2005 04:57 AM
tgreaves
Apr 8, 2005 10:19 AM
faSHOwidIT
Nov 15, 2004 03:57 AM
