Loctite on pressure plate bolts?
Old Jan 6, 2003 | 04:13 AM
Finest's Avatar
Default Loctite on pressure plate bolts?
https://honda-tech.com/zerothread?id=374522
I found out why I couldn't get into gear in my H22. Turned out that one of the bolts holding the pressure plate actually backed out and banged around in the tranny, hence the rattling noise that developed. I found out after having to pull the tranny, which is a POS in itself. Also, I found out that 3 other bolts were loose, which I can turn by hand.
So my question is, should I use loctite on these bolts? I'm lucky the bolt didn't fall between the clutch disc and flywheel...but my pressure plate cover took quite a beating! I'll take pics and show you the damage that one bolt can do.
Old Jan 6, 2003 | 04:56 AM
337 GTI 1.8t's Avatar
Default Re: Loctite on pressure plate bolts? (98CTRCoupe)
Yes, use Loc-tite and proper torque spec. on said bolts to prevent what you described.
[Modified by GTI 1.8t, 2:28 PM 1/6/2003]
Old Jan 6, 2003 | 05:53 AM
88_SC_CRX_Si's Avatar
New User
Might go ahead and just replace them. They have been stretched, and will tend to give you false torque readings, in one way are another...
"I" would go with the "red" in this case, then use laquoer(sp) thinner to remove them. If they gave me any trouble getting them out....
[Modified by 88_SC_CRX_Si, 7:01 AM 1/6/2003]
Old Jan 6, 2003 | 08:26 AM
Finest's Avatar
Default Re: Loctite on pressure plate bolts? (88_SC_CRX_Si)
Thanx! I only asked because the manual didn't mention anything about using loctite or other adhesive on these bolts. Well, I'd rather be safe and have to go through the process of dropping my tranny again!
Old Jan 6, 2003 | 01:07 PM
7PSI CRX's Avatar
I'd stay away from Loctite* RED.
You'll never get those bolts off again without a torch.
Just torque them to the proper specs.
Old Jan 6, 2003 | 01:10 PM
gtpilot's Avatar
Default Re: Loctite on pressure plate bolts? (7PSI CRX)
I have never had to use Loctite on those bolts and I have rebuilt and replaced my race motors over 30 times in the last ten years. I have always just used a torque wrench and made sure the threads were lubed before tightening them up.
Kirk
Old Jan 6, 2003 | 02:11 PM
Chiovnidca's Avatar
Don't use Loctite.
Old Jan 6, 2003 | 04:08 PM
sneakychaos's Avatar
Default Re: Loctite on pressure plate bolts? (Chiovnidca)
...in fact, most companies who sell aftermarket flywheels print in nice big bold letters, "DO NOT USE LOCTITE ON FLYWHEEL BOLTS". Heh... Use proper torque specs on these bolts. Torque them down, loosen and then re-torque.
Old Jan 6, 2003 | 05:45 PM
earl's Avatar
Default Re: Loctite on pressure plate bolts? (sneakychaos)
We're talking pressure plate bolts, not flywheel bolts. Pressure plate bolts require a lot less torque than flywheel bolts. I can't see any reason not to use loctite and you do not need a torch to break them loose. It's not like it is JB Weld, just a product to stop the bolt from vibrating out in a low torque situation.
Old Jan 7, 2003 | 03:09 AM
Chiovnidca's Avatar
Default Re: Loctite on pressure plate bolts? (earl)
If properly torqued, they aren't going to get loose.
Old Jan 7, 2003 | 04:33 AM
Finest's Avatar
Thanx...and yes I was talking about the pressure plate bolts. Definitely not the flywheel bolts!
The manual says 19lbs/ft. I rev out to 7500rpms almost daily. I think I'm going to use loctite.
Old Jan 7, 2003 | 04:43 AM
I agree, those bolts have been known to come out despite careful attention to torque, ask bigstothel. Clutchmasters has suppied thread locker with some kits in my experience. Use Loctite.
[Modified by GTI 1.8t, 1:45 PM 1/7/2003]
Old Jan 7, 2003 | 04:51 AM
Ricky Rojales's Avatar
Default Re: Loctite on pressure plate bolts? (GTI 1.8t)
appelsos
15
May 15, 2013 03:03 PM
slowassciv33
Aug 23, 2006 08:20 AM
civic_driver
Nov 9, 2005 11:54 AM
jlv55
Jul 17, 2004 02:38 PM
