a little help from hondata peeps
i currently have 1st gen b16 with the pr3 ecu. I just recently purchased hondata stage 4 b with hondalogger. i do not have the programmer for it yet, and my engine is almost stock. what esle do i need to tune this myself??
near future plans are: (so you have an idea)
custom turbo kit (12 lbs at the track)
bored TB
slight head work
lsd
this is what i think i need.
wide band o2 sensor (wich one should i go for)
2 or 3bar map sensor (does it matter wich one)
programmer
emulator (to make tuning easier)
chips
i was going to purchase most of the above at http://www.c-speedracing.com
are there any other places with better prices?
thanks for your help!
bored TB
slight head work
lsd
programmer
chips
Somewhere out there I believe there are sample rom files you can download of engine setups that may be similar to yours. This way you have a viable primer that should set you in the right direction, then you can fine tune it along the way.
I thought Hondata had these on there web page so that poeple could start off alot easier, but after a quick glance through I didn't see anything. Maybe someone else knows.....
Good luck.
Good luck.
Heres something like what I was thinking, I just don't know how to actually get the rom files.....
http://www.hondata.com/tunerlibrary.html
