Lift/Duration of GSR cams while NOT in VTEC
Old Jan 3, 2006 | 04:31 PM
bdavis's Avatar
Default Lift/Duration of GSR cams while NOT in VTEC
I have found what they are while in VTEC, but I would like to know them while on the NON-VTEC lobes. I am crunching some numbers and doing some research for my Master's thesis, and would much like to know
Thanks
Burke
Old Jan 3, 2006 | 09:27 PM
shorto85's Avatar
INTAKE lift - 10.6 mm,duration - 230 @1mm
EXHAUST lift - 9.4mm, duration - 227@1mm
Old Jan 4, 2006 | 06:50 AM
bdavis's Avatar
Default Re: (shorto85)
thanks for the help, but those are the cam specs while in VTEC. i found those guys already
I am looking mostly for the duration while NOT in Vtec
thanks in advance
Old Jan 4, 2006 | 09:23 AM
Scott_Tucker's Avatar
Those specs are also at 1mm which have no meaning in the real world. The valve is already flowing a bit of air at that point, if you are doing your masters thesis I suggest you get seat-to-seat numbers for accuracy. If you have a cam you want checked I can check it for you.
-Scott Tucker
Old Jan 4, 2006 | 09:55 AM
bdavis's Avatar
Default Re: (AutoEng2002Si)
thanks for the reply! I know those ones are at 1mm, I have found them at no lift as well, which are the ones I was going to use.
I am doing dynamic CFD on intake manifolds, so I would like to know how long each valve is open. and then will be estimating the pressure at the end of the intake port while valve is open. I am very interested in your help, if you have the time.
I read your bio in your profile and WOW! any help you can offer is MOST appreciated. if you can pm me with some contact info, I would love to pick you brain.
Thank you very much
Burke
killerpenguin21
18
Nov 25, 2008 12:33 PM
92CivicLS
May 13, 2008 08:59 AM
JohnnieChimpo
Jul 19, 2005 08:17 AM
bugster
Jan 28, 2005 10:18 PM
Mr.FBR
Nov 26, 2001 05:05 AM
