.....> lets talk about affects of Boring the B16
Old Mar 3, 2003 | 06:23 AM
Charlie Moua's Avatar
Default .....> lets talk about affects of Boring the B16
Well i'm thinking about boring & sleeving my B16a1 to 85mm. It will not affect the R/S ratio, for those who think I'm crazy. I know this will result in MORE displacement & HP but will it make more toqure?
Will this the B16a power CURVE & power BAND be simalar of a B18c and C5?
Old Mar 3, 2003 | 07:39 AM
CHEETAH's Avatar
Default Re: .....> lets talk about affects of Boring the B16 (Charlie Moua)
I assuem you're talking about comparing it to a stock bore 81mm b18c motor ...
the high compression b16a motor bored 85mm will make slightly more TQ than a built up high compression b18c motor, but the b16a will make much more HP because it will peak at a higher RPM even with stock cam vs. stock cam. I did this couple times. Also, if you use the Toda spec B or C cams in the b16a, you'll need to switch around 6900rpm to 7100rpm (most vtec controllers can;t switch past 7k rpm - thats where I usually come in and reprogram people's ecus )
nice project, btw ...
Greg
Old Mar 3, 2003 | 07:58 AM
Default Re: .....> lets talk about affects of Boring the B16 (CHEETAH)
thanks for the advice.
Yes i want to go B16 but would like a "tad-bit" more toqure for daily driving.
I'll IM you about more questions i have on my setup.
Old Mar 3, 2003 | 02:37 PM
TTT anyone else?
athbaseball23
41
May 6, 2011 04:05 PM
-Whitey-
82
Feb 26, 2003 03:57 PM
weakGOODJunKieS.com
Oct 2, 2002 05:03 PM
Civicexb16a2
10
Sep 28, 2002 11:07 PM
DOHC b16a VTEC
Jun 17, 2002 01:05 PM
