leakdown on k20a2
Old Apr 4, 2004 | 09:49 PM
eg4sheezy's Avatar
Default leakdown on k20a2
I just checked out a type s engine. Did a leakdown on it with results 20% in cyl. 1,2 and 4. Cyl 3 wax leaking 40%. Now, i would like to know if these are decent numbers, mind you, the engine is not sitting in a car and not a normal operating temperature. test was done with engine sitting on the ground. Im guessing the valve seals are fully expanded.
Also, there was an oil stain on the cardboard the engine was sitting on. Looked under the engine and saw (what i think) a chip where the tranny casing meets the block. The chip is on the tranny side and goes through the casing (oil leaking). What could have caused this?
please help out
thanks
Old Apr 4, 2004 | 11:11 PM
eg4sheezy's Avatar
Default Re: leakdown on k20a2 (eg4sheezy)
help?
Old Apr 5, 2004 | 03:01 AM
non-VTEC's Avatar
thats allot of leakdown for a relitivly new engine. unless you didnt do the leak down test properly i would say that engine is fucked.
Old Apr 5, 2004 | 08:18 AM
eg4sheezy's Avatar
could the numbers be low because the engine wasnt nearly close to being at full operating temperature (ie. valve seals NOT expanded might cause leak?)
anyways, gonna open up the oil pan and see what i could find.
Anybody else?
Thanks
Ps. if the motor is fucked, can i get my money back from the POS who sold it to me like by going to the cops or something?
Old Apr 5, 2004 | 05:45 PM
eg4sheezy's Avatar
Default Re: leakdown on k20a2 (non-VTEC)
what about the hole in the tranny casing?
eg4sheezy
Apr 5, 2004 07:19 PM
eg4sheezy
Apr 5, 2004 05:41 PM
eg4sheezy
Apr 5, 2004 08:19 AM
eg4sheezy
Apr 5, 2004 08:17 AM
eg4sheezy
Apr 4, 2004 11:10 PM
