Leak Down Test Results
Old Aug 16, 2002 | 08:14 PM
hybrid901's Avatar
Default Leak Down Test Results
I did a compression test a few days ago and my numbers were roughly 1 thru 4 185, 170, 170, 130 so we did a leak down test tonight. With a 100 psi pressure I had 93, 93, 90, 39. I have no idea how long its been low since this is my first leak down ever and first compression test in about 6 months. It might have something to do with me driving on 14+ psi everyday. I'll be going to the track tuesday to see if my mph has dropped since my last run 2 weeks ago. Will cylinder 1 fail soon if I keep boosting? I'm hoping it will last until I get my 2.0 gsr built.
Old Aug 16, 2002 | 10:55 PM
TREVER's Avatar
Default Re: Leak Down Test Results (hybrid901)
If you did your leak down test correctly you should know where your compression is going. Either way it sounds like its time for a tear down.
Old Aug 17, 2002 | 03:26 AM
Chiovnidca's Avatar
Drive it till it drops.
Old Aug 17, 2002 | 09:16 AM
Aceman64's Avatar
Default Re: Leak Down Test Results (Chiovnidca)
You have 61% leakdown in a cylinder and your going to the track to run . Seems like it would be logical to take it easy on the engine so you know for sure it will last until you get your other engine finished. Just my opinion of course.
-Ace
Old Aug 17, 2002 | 10:12 AM
Kamin's Avatar
common sense
dont RACE IT if you want it to last
you obviously have a big problem.
Old Aug 18, 2002 | 07:31 PM
memphiss13's Avatar
Default Re: Leak Down Test Results (C5_ALLMOTOR)
you guys obviously don't know josh, he kills motors left and right. i think he likes to blow them up.j/k (I hope thats not true) this is about the longest i have ever seen him go without blowing it.
[Modified by rookie2nr, 10:32 PM 8/18/2002]
Old Aug 19, 2002 | 06:11 AM
hybrid901's Avatar
Default Re: Leak Down Test Results (rookie2nr)
I'll be at the track tuesday night to test my new axles.
liquidzorch
Sep 13, 2013 07:33 PM
niterider96cord
Jun 22, 2010 07:46 PM
JConto
12
Feb 23, 2010 10:01 AM
SPOON_FED_DC_2
Apr 6, 2005 09:19 PM
Chubz
Jun 28, 2002 09:25 AM
