last minute brake question
Old Sep 8, 2003 | 06:19 PM
stock97's Avatar
Default last minute brake question
is it true you can damage the ABS when changing pads??
also what kind of brake pads should i buy?
just doing the rears
Old Sep 8, 2003 | 09:37 PM
stock97's Avatar
Default Re: last minute brake question (stock97)
anyone?
Old Sep 9, 2003 | 07:34 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock97 &raquo;</TD></TR><TR><TD CLASS="quote">is it true you can damage the ABS when changing pads??</TD></TR></TABLE>Well, sure you can. Why would you want to?
OK just kidding... The sensors at each wheel are mounted to read a toothed ring somewhere on the rear hub or on the front CV joint. You'll see the wires when you take your brakes apart.
Just like you have to be careful not to pull the hydraulic hose apart, you also have to be careful not to mash the wheel sensors or pull their wiring apart. It's pretty easy to avoid damaging them.
Search about brake pads. There's pros & cons for all the different choices. ABS doesn't really care which kind you get.
amej8
Honda Civic (2006 - 2015)
Sep 5, 2012 05:42 PM
lude98SH
Dec 2, 2006 09:24 AM
Senbonzakura
Dec 22, 2004 04:13 PM
civicboy95
Aug 20, 2004 10:51 PM
drive
15
Oct 10, 2002 07:19 PM
