Knocking sound during startup
Old Apr 13, 2009 | 05:53 AM
igrek's Avatar
Icon2 Knocking sound during startup
There is a knocking sound.mp3 for a few seconds just after I fire up the engine (euroR H22). The bottom is stock and never opened in fact. I installed JUN camshafts and valve spring a several hundred miles ago. I tried a new oil filter and changed oil - did not help. I also tried removing alternator/aircon driving belt - did not help either. I guess it has something to do with oil not getting somewhere. My oil pressure gauge is not powered during cranking, but after the engine starts the pressure is about 85psi/5.8bar and 15psi/1bar in idle. So, guys, any ideas what could make the sound?
Old Apr 14, 2009 | 06:09 AM
dognutz's Avatar
Default Re: Knocking sound during startup
Could be Excessive play in your bearings from high milage, time for a rebuild.
Old Apr 14, 2009 | 06:36 AM
alterdcreations's Avatar
before you spin one
Old Apr 14, 2009 | 06:56 AM
igrek's Avatar
It has 32000 miles, so if the bearings are worn it is not because of mileage...
Old Apr 14, 2009 | 08:38 AM
Battle2.0Eg's Avatar
Lma's ?
Old Apr 14, 2009 | 08:49 AM
InvaderTrax's Avatar
Sounded kinda valve-ish to me. I know one of mine does that because the valves stick really bad. Could be that your motor sat for many years, moisture got in and corroded the valve guides
Old Apr 14, 2009 | 08:53 AM
igrek's Avatar
Originally Posted by Battle2.0Eg
Lma's ?
Brand new. And they are just springs, so they can't stick. I would guess they could cause problems if they are weakened over time, but that is not the case.
Old Apr 14, 2009 | 09:26 AM
mouab18c1's Avatar
alot of cars have knocking sounds at cold start ups...it usually goes away once the oil circulates through the motor...what oil are you running?
Old Apr 14, 2009 | 09:37 AM
igrek's Avatar
Motul 300V 5W40, tried 5W30 too.
b20ricepower
Feb 5, 2014 03:59 PM
b20ricepower
Dec 16, 2013 07:44 AM
LS97Civic
Apr 24, 2012 07:48 AM
chrisff521
Jul 11, 2009 01:35 PM
jvtec95
May 22, 2005 03:33 PM
