KNOCK SENSOR......SEARCHED !
Old Dec 3, 2006 | 06:19 PM
vtecp0wa's Avatar
Default KNOCK SENSOR......SEARCHED !
I'm running my 1990 LS with a swapped motor. ECU is obd0 PW0. The problem I'm encountering is the new block does not have a slot for the knock sensor. So its basically dangling behind the motor. However my ecu still checks for it and no one seems to be able to kill it. I've asked alot of people for a flash chip to disable it but no one seems to have it.
I also was told by a ecu guru to solder a wire from the knock sensor to a good known ground on the chassis.
Still didnt work.
Anybody out there have any other ideas ?
Old Dec 3, 2006 | 06:33 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
what block are you using, and what harness are you using? 1990 integras don't have knock sensors.
it sounds like your using an obd1 harness on an obd0 setup. is your harness hacked up at all?
Old Dec 3, 2006 | 06:36 PM
ekb16's Avatar
u would actually have to tread a place on the black for it
Old Dec 3, 2006 | 07:05 PM
vtecp0wa's Avatar
Default Re: (full Circling)
My Harness was never touched.
I believe its a 94 LS Block.
My 90 LS Motor did have a spot for the KS.
Old Dec 3, 2006 | 07:08 PM
vtecp0wa's Avatar
Default Re: (ekb16)
I dont want to drill a hole in my block for that useless sensor. I just wanna disable it. FOR GOOD !
Old Dec 3, 2006 | 08:00 PM
JimBlake's Avatar
Default Re: (vtecp0wa)
94 LS doesn't have a knock sensor. Only the GSR has it.
Old Dec 3, 2006 | 08:35 PM
vtecp0wa's Avatar
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">94 LS doesn't have a knock sensor. Only the GSR has it.</TD></TR></TABLE>
My Point Exactly I have no were to put it, and it retards my timing sparacticly because the ecu is looking for it.
Old Dec 4, 2006 | 06:40 PM
JimBlake's Avatar
OK, I get it now. But I'm still surprised that a '90 LS would have a knock sensor.
Old Dec 4, 2006 | 07:00 PM
92GSR HB's Avatar
how do u have a knock sensor on a non vtec motor?
Old Dec 4, 2006 | 07:03 PM
qfast817's Avatar
Default Re: (92GSR HB)
you can get a chip and have it disabled
Old Dec 5, 2006 | 08:51 AM
vtecp0wa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92GSR HB &raquo;</TD></TR><TR><TD CLASS="quote">how do u have a knock sensor on a non vtec motor?</TD></TR></TABLE>
I got an LS/Vtec.
Old Dec 5, 2006 | 08:53 AM
vtecp0wa's Avatar
Default Re: (qfast817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">you can get a chip and have it disabled</TD></TR></TABLE>
Tell Me who. So far Phearable.net and Kenji211 dont have programs for it and they are both pretty big.
92GSR HB's Avatar
so are u tryin to eliminate the knock sensor on the ecu or are u tryin to say u have on ur block cuz i know LS dont have em.
Old Dec 5, 2006 | 09:07 AM
vtecp0wa's Avatar
I want to run my motor with no CEL. The CEL is throwing knock.
The block has no slot for the KS. I want to disable or anything else that is possible for the ECU not to read it or look for it.
I heard something about running the knock back to the ECU to slot B19 or something but I have no clue how to do it.
Old Dec 5, 2006 | 05:44 PM
HondaPartsHero's Avatar
Technical Hero
http://www.c-speedracing.com/h...c.php
bottom of the page
Old Dec 5, 2006 | 09:41 PM
vtecp0wa's Avatar
&lt;-- Doesnt want to drill or tap anything just disable it for good.
Sorry for being so picky but in my engine bay I dont have room for that the motor is in the car. That would be a piece of cake if it was out of the car.
Old Dec 5, 2006 | 11:59 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecp0wa &raquo;</TD></TR><TR><TD CLASS="quote">&lt;-- Doesnt want to drill or tap anything just disable it for good.
Sorry for being so picky but in my engine bay I dont have room for that the motor is in the car. That would be a piece of cake if it was out of the car. </TD></TR></TABLE>
Well you've searched and asked ECU experts, and no one has chipped OBD0 ECU's... so, you can either do what was suggested above and just put the sensor someplace else, convert to OBD1 and use a chipped ECU, or just ignore the CEL.
Old Dec 6, 2006 | 01:29 AM
Technical Hero
Default Re: (JDM_Ej)
https://honda-tech.com/zerothread?id=1181854
projectef
Apr 26, 2007 05:52 PM
lsvtec2000SI
Mar 14, 2005 12:32 PM
black-hatch
Jan 5, 2003 01:17 PM
