knock sensor ? high comp b20b or low? pics inside
^here is where i think my knock sensor was
my set up is obd2 to obd1 im running a jumper harness, my motor i think is a 2000 here you can see a 0/ and the other 0 but i can barley see it
im tryin to clarify its a 2000
ok once again for 98vtec. i want to know of my motor is a 2000 . i am running a p75 obd 1 ecu. i have a jumper harness for obd1 to obd2
what are you wanting to actually know? you may not be getting clear answers because you questions are not clear.
and if you are running a p28 ecu, it doesnt have a knock board.
all engines have VIN plates on them which would determine the year, that is unless someone decided to be a smart as and remove it.
I'm just failing to understand why it matters and since this is a TECH discussion section of this forum, we would like to know details.
a non blurry picture would probably help too.
Moving to tech/misc
why does it matter?
Moving to tech/misc
Moving to tech/misc
ok so how do i find out what year it is. i have that vin. i want to know if my motor is the high or low compression....
4door93civic
Apr 11, 2007 10:16 PM
