jdm itr compression results
Old Nov 18, 2002 | 12:06 PM
2XS's Avatar
2XS
Default jdm itr compression results
I just got my jdm itr installed, and did a compression test. I got 185-190 accross all of them. I expected it to be also higher, can anyone tell me if this is what I should have expected, with those engines in the 11:1 comp area
Old Nov 18, 2002 | 04:46 PM
B16b2b's Avatar
Default Re: jdm itr compression results (2XS)
thank you very much check out my post....https://honda-tech.com/zeropost?cmd=reply&id=3360479
maybe we're missing something here???
Old Nov 18, 2002 | 07:26 PM
2XS's Avatar
2XS
Default Re: jdm itr compression results (B16b2b)
I think I missed something, btw, how much for your cams?\
pm or email me on them
Old Nov 19, 2002 | 06:16 PM
myhatchrips's Avatar
seems pretty low. i hae a 94 jdm gsr motor and my compression on all four cylinders are 230. my cars uses about 1 1/2 quarts between 3000 mile oil changes but still rips!
Old Nov 19, 2002 | 07:28 PM
InevitableRace's Avatar
Um its a JDM ITR...And it has a read valve cover......
Do you really think the guy that had that motor in his ITR in Japan drove the car normal...I dont think so....Im sure that guy beat the **** out of it..Because it has a red valve cover...And its an ITR motor....
So for now just drive the car until you can afford to rebuild it...being that low isnt that bad....
Did you do the test when the motor was hot or warm and wide open throttle????If not try that....
Thanks
Ross
Old Nov 20, 2002 | 12:22 PM
chad's Avatar
Moderator
that does sound kinda low....even for a beat to **** itr!
Nameless RB26
Mar 27, 2005 09:52 PM
SupaFly_Honda
Oct 26, 2003 01:37 PM
TEAM562racing
Oct 15, 2003 01:55 PM
p-boy
Jan 20, 2003 10:13 PM
