JB Weld???
Old Jan 3, 2007 | 05:25 AM
mrmckie's Avatar
Default JB Weld???
Has anyone has any previous experience w/ this product? I have a leak in my tranny and heard this stuff is damn near as good as getting it welded. What your experience with it good, bad, alright?
Old Jan 3, 2007 | 05:39 AM
mmuller's Avatar
Mad Scientist
Default Re: JB Weld??? (mrmckie)
where is your tranny leaking from?
if its like a crack it wont work for long..
Old Jan 3, 2007 | 05:51 AM
mrmckie's Avatar
Not really a small crack b/c is has a slow steady drip looks like whoever had the car before me hit something and the damaged it causing the leak, theres a clump of compound(or watever u call it over it) dats where the drip seems to be comming from. Its drips at a slow steady pace like every 5 sec or so.
A fellow member told me about JB Weld and said it was really good. How long would it hold? If it can hold like a week or 2 thatsgood, by then i should be able to get a new tranny.
Old Jan 3, 2007 | 06:00 AM
mmuller's Avatar
Mad Scientist
Default Re: (mrmckie)
it might hold for a little, make sure you grind around the area
not possible to weld?
Old Jan 3, 2007 | 06:17 AM
mrmckie's Avatar
i found a shop that welds so i wanna have them look at it and then really decide if i should weld or jus get a new one.
Old Jan 3, 2007 | 03:45 PM
mrmckie's Avatar
anyone else w/ experience or recomendations on other products?
Old Jan 3, 2007 | 03:50 PM
Bense's Avatar
i wouldn't use jbweld to get the trans halves together
Old Jan 3, 2007 | 05:05 PM
Scott_Tucker's Avatar
JB Weld is just two-part epoxy. It may seal a small crack but if your trans has a crack in it it liable to expand the crack a little bit when you shift. This would break the epoxy possibly.
Old Jan 3, 2007 | 07:31 PM
mrmckie's Avatar
koo, bump the jb weld den. i'll see how much it cost to weld, if it cost almost as much as a new tranny i'll jus pick up a new one
thanks again fellas
Old Jan 4, 2007 | 04:50 AM
bart2546's Avatar
JB Weld FTW! But as others have said, it depends on your situation, if it's small crack, like a hairline crack I'd say go for it but if there's generally a HOLE there nah I wouldn't put THAT much faith into it, I mean for example it really can't hold cracks on an exhaust manifold due to heat and pressure but it works for a lot of other crap.
Old Jan 4, 2007 | 10:01 AM
Jakester9500's Avatar
yea, it works for little crap. But so does super glue. I never really get JB Weld to work right for the things I want it to work for. I don't think it would cost too much just to get it welded.
cheeto_89ef
Oct 4, 2009 03:22 PM
sp00ledbseries
Welding / Fabrication
May 7, 2009 12:20 PM
egzo04
Jun 6, 2007 06:09 AM
B bOy CrAyOn
13
Jun 2, 2005 09:25 PM
staticrex
11
Jan 7, 2005 11:13 AM
