ITR intake manifold
Old Nov 28, 2007 | 09:04 PM
DOHC4banger's Avatar
Default ITR intake manifold
i currently have an EM1 and im very interested in getting
a ITR intake manifold...but would i have to dyno tune because
of the change in air flow or is it just bolt on without tuning?
Old Nov 29, 2007 | 01:43 AM
hellakapps's Avatar
Default Re: ITR intake manifold (DOHC4banger)
i'm guessing your n/a and i would not tune if your only doing the im, you won't see much gain if you don't tune, but i would try to do a few more mods(header, tb, intake, cams) before you spend the money to tune, than all the mods can work together and you'll see a gain. it won't lean the motor to a point of harm enless your boostin
Old Nov 29, 2007 | 03:58 AM
B16B_coupe's Avatar
HRD PKR
Default Re: ITR intake manifold (hellakapps)
you should be fine not tuned, but i would def get the rest of the bolt on's then tune
Old Nov 29, 2007 | 07:54 AM
Default Re: ITR intake manifold (B16B_coupe)
ya i was planning on getting more bolt ons before the tune
but it would harm the motor if i boosted??
Old Nov 29, 2007 | 08:14 AM
JMsports's Avatar
Honestly theres no need to tune just for bolting on a intake manifold. Its not like u are modifying the engine enough where you need to adjust ignition curves, A/F ratios, etc.
Depends how much you plan on boosting! before boosting, I would get more mods bro that will aid you and the turbo setup. More fuel, more spark, high lift/low duration cams, etc. When you boost, your engine demands alot, even at a measly 5-7 PSI. If your A/F ratio isn't correct when in boost, get ready for strange noises and to spend alot of money to make up for what wasn't done right the first time. For example, I always have customers at the machine shop who ask me "how much power will I see from the PnP job you did" and honestly, I dont have an answer for them if thats all they ask and dont tell me anything else. Bolting on a head thats been heavily worked and is about to flow about 20% air will need more fuel and spark to compensate for the added air. So same thing applies to you, if you plan on boosting and cram all that air in the engine, then like i said before, make sure you have the proper parts otherwise that time and money was wasted. good luck on the build
Old Nov 29, 2007 | 08:29 AM
Default Re: ITR intake manifold (JMsports)
im definately not boosting anytime soon but thats good info for the future but i have planned to get more mods before anything else
the ITR intake manifold tuning question was cause me and a friend had different opinions about the airflow change
thanks for help and anymore comments would be appreciated
Old Nov 29, 2007 | 08:45 AM
King V's Avatar
"I chose to use an ITR intake manifold and the larger ITR throttle body because they just dominate the B16 manifold past 6-7k. But, on the downside, as a general rule, the B16 manifold makes more power upto 6-7k. It just really depends on where you plan on making power"
Quote from BamBam in his "how to build a reliable LS/VTEC" post in All Motor.
Old Nov 30, 2007 | 04:23 AM
Default Re: ITR intake manifold (King V)
i decided to get it its a jdm type r intake manifold with ported intake runner
FlewByU352
Nov 16, 2009 09:25 PM
Al-sonic
Jan 16, 2008 09:19 AM
jtd87man
Sep 24, 2006 04:32 PM
Cesare1987
Nov 7, 2005 11:15 AM
iperez
Dec 5, 2003 11:01 AM
