ITR flywheel questions ..
Old Feb 22, 2004 | 03:34 PM
redlineintegra's Avatar
Default ITR flywheel questions ..
tried searching, but can't find the answer I am looking for.
I am building an all motor LS (b18a), and bought a ITR flywheel .. looking at my service manual, I need 9 pressure plate bolts, but my ITR flywheel has only 6 threaded holes? Can someone with experience on this tell me if I need to order the 90-91 clutch kit, or will the pressure plate bolts not line up?
Thanks .. pics of an LS wheel would help alot too.
Old Feb 22, 2004 | 04:02 PM
boostn420's Avatar
Default Re: ITR flywheel questions .. (redlineintegra)
Well I believe the 90-91 tranny input shaft is smaller so you have to use that clutch. I also think that there are nine holes on the later model pressure plates but you only use 6 because the flywheel. In other words go with the 90-91 clutch.
Old Feb 22, 2004 | 04:15 PM
Default Re: ITR flywheel questions .. (boostn420)
Thanks for the reply, that was my thinking too .. good thing because my clutch is on its way heh.
arren123
Oct 31, 2006 06:10 PM
Integra91LS
Sep 10, 2003 01:44 PM
See Are X
Jun 18, 2003 03:57 AM
thecorey
Sep 27, 2002 03:03 PM
