ITR engine
Old Jun 30, 2008 | 10:41 AM
ITR-EKcoupe's Avatar
Default ITR engine (pics)
my itr has a spun rod bearing... i tore it down yesterday to inspect and sure enuf #1 rod bearing is done. took the bearing cap off an theres not much bearing left. there was some really fine shavings on the bottom of the pan but nothing big. at the very bottom of the cylinder there is a spot on both sides where you can see where the rod cap was hittin the block, but its so minute its not worrying me as the motor was shut down fairly quickly, or so i was told. i have been doing some research on the LS crank swap and its seeming like a fairly decent option right now as im not too sure how healthy my crank is. im going to get some pics up in the next few mins here so u guys can help me make a decision as to what i should do. any oppinions are greatly appreciated.
Thanks - Justin
Modified by ITR-EKcoupe at 12:38 PM 6/30/2008
Old Jun 30, 2008 | 11:29 AM
Default Re: ITR engine (ITR-EKcoupe)
PICS
http://i56.photobucket.com/alb...6.jpg -bearing cap
http://i56.photobucket.com/alb...7.jpg
-bearing cap
http://i56.photobucket.com/alb...8.jpg
-bearing cap
http://i56.photobucket.com/alb...0.jpg
-crank
http://i56.photobucket.com/alb...9.jpg
-rod
-where the rod hit the cylinder
-crank
http://i56.photobucket.com/alb...5.jpg
http://i56.photobucket.com/alb...4.jpg
-where the rod hit
http://i56.photobucket.com/alb...3.jpg
-where the rod hit
http://i56.photobucket.com/alb...1.jpg
-rod
sorry for the pics...cams only a 4 megapixel
i named all the pics so u know what ur looking at...hopefully it worked
Modified by ITR-EKcoupe at 12:35 PM 6/30/2008
Old Jul 1, 2008 | 12:00 PM
hotrod99's Avatar
just have your type r crank sent out to micropolished and balanced,im sure you can still use it
Old Jul 1, 2008 | 06:53 PM
DOHCter's Avatar
I would get the crank x-rayed, or eddie current inspected for cracks or flaws. I spun a bearing in my ITR block and the crank had a small crack unseen to the eye.
Hatch3d
Aug 12, 2015 09:47 AM
Mitch11Bravo
Feb 26, 2015 08:42 AM
dallasyoung
Nov 2, 2011 04:53 PM
soon2bdropped
Dec 14, 2010 03:42 PM
hksbigboi4
Apr 16, 2004 07:48 AM
