ITR driveshafts compatible for b16a?
Old Jun 28, 2007 | 07:57 AM
Mohsin's Avatar
Default ITR driveshafts compatible for b16a?
Hi All,
Will an ITR axel / shaft fit on a b16a engine / gearbox?
Car: EG6 SiR with LSD.
No ABS
Thanks.
Old Jun 28, 2007 | 10:36 AM
Mohsin's Avatar
Default Re: ITR driveshafts compatible for b16a? (Mohsin)
anyone?
Old Jun 28, 2007 | 10:40 AM
Padawan's Avatar
Darth ModerVader
Yes.
Old Jun 29, 2007 | 01:10 PM
Mohsin's Avatar
Default Re: ITR driveshafts compatible for b16a? (Padawan)
just to confirm - they are JDM ITR axles, i heard there is an issue regarding huz size (ITR - 36mm) eg6 32mm?
ty
Old Jun 29, 2007 | 02:22 PM
Padawan's Avatar
Darth ModerVader
If they're JDM ITR axles (which you didn't mention in your original post) then no, they won't fit your hubs. As you stated, the JDM ITR axles are 36mm, and your hubs are 32mm.
Old Jun 30, 2007 | 03:57 PM
EG2Driver's Avatar
also make sure they are non-ABS axles
Old Jul 1, 2007 | 11:18 PM
92_VX_EG's Avatar
Default Re: ITR driveshafts compatible for b16a? (EG2Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2Driver &raquo;</TD></TR><TR><TD CLASS="quote">also make sure they are non-ABS axles</TD></TR></TABLE>
You can use ABS or non-ABS axles if your car doesn't have ABS. Only ABS cars have to have ABS axles. If you don't want the ABS ring on them you can tap them off with a hammer and screwdriver.
KnuckleZ
Jan 5, 2011 06:45 PM
krysted9354
Apr 9, 2010 02:52 PM
4play4dr
Aug 3, 2006 05:28 PM
00CIVICSITEIN
Mar 15, 2004 02:53 AM
Hard2Find
Jan 25, 2002 10:01 AM
