ITBs, fuel management, vacuum...
Old Dec 23, 2002 | 02:16 PM
  #51
Hrate's Avatar
Default Re: ITBs, fuel management, vacuum... (HavokRacing)
i still have a set of twms,i used it prev with tec2,i ve got the itch to put it on my new all motor setup, i planned on using a p28 this time with a mugen program to disable aic,what did you do to help with map vacuum fluctuations?(how big of a canaster) also where is a good place to order new air horns? i had to hack mine to make a plenum for forced induct.
Old Dec 24, 2002 | 03:10 AM
  #52
Jeff C's Avatar
Default Re: ITBs, fuel management, vacuum... (Hrate)
On the vacuum canister situation...(quoted from CHEETAH)
use the canister from a gsr that controls the secondary runners, just drill and tap a hole to connect the brake booster, it is sufficient to build excellent vaccum, mine picks up a good 325mm @ 1Krpm
On buying new horns, maybe check with these guys...http://www.jenvey.co.uk/
Got my 929RR ITB's last night, now I just need to recieve the b16 mani and then its time to play.
twocross
29
May 3, 2011 01:03 PM
EJ8chu
Engine Management and Tuning
32
Jun 1, 2008 10:19 AM
Running925
Dec 2, 2006 09:24 PM
machine4321
31
Jul 10, 2004 08:16 PM
civicracer1993
Feb 24, 2003 07:25 PM
