integra swaybars
Old Jan 18, 2002 | 12:56 AM
96whitels's Avatar
New User
Default integra swaybars
i was wondering if the front swaybar 94+ ls tegs be able to us a grs of type-r front swaybar?? Also what kind of modifcations would it need?? Also on the rear sway is there any kit that i would be able to use to mount the type-r sway without using new bolt holes or modifying it to fit? What im asking is there a kit that make it just bolt straight in??
Old Jan 18, 2002 | 06:25 AM
BSQ's Avatar
BSQ
Default Re: integra swaybars (96whitels)
Go to https://honda-tech.com/zerothread?id=115249 for information on this topic.
[EDITED]Link above has been corrected[EDITED]
[Modified by BSQ, 12:17 PM 1/18/2002]
Old Jan 18, 2002 | 10:14 AM
SyndicateEH's Avatar
Yes a 24mm(gsr) front bar will work. You will need the D brakets and endlinks off a gsr. To put a 22mm (type R) you will need gsr or type endlinks. I used the Beaks mouting kit for the needed subframe re-inforcement. (works great! and many others use it) . For the D brakets i'd get some energy suspension or prothane. Altough, i'm not sure if the LS subframe is the same as a type r... if it is you could just use the complete type r setup...
Heres a relativly clear pic of the type r bar, energy sus D braket and beakts mounting kit. http://www.tasam.com/~amrit/amrit/itrl.jpg
good luck
Hybrid CRX
Jun 7, 2003 02:27 PM
rota426
Oct 7, 2002 06:13 PM
Nick248
Mar 29, 2002 05:28 AM
96whitels
Jan 18, 2002 10:01 AM
fuguman
Oct 2, 2001 04:55 AM
