Integra squeaking like a mofo when idling.. help!
Old Apr 17, 2002 | 06:17 AM
harryg's Avatar
Default Integra squeaking like a **** when idling.. help!
Posting this here since the other forum doesn't have anything to say
Argh.. this has been a consistent problem.. more like a major annoyance for me for the past few months. At idle, and as I increase the RPM, a high pitched squeal emits from the drivebelt area under the hood. I've checked it out, and it is almost certainly coming from the crank pulley. What can I do to fix this? Like I said, it doesn't seem to be coming from any of the accessories, but from the crank pulley itself. Thanks.
Old Apr 17, 2002 | 09:14 AM
erniecars's Avatar
Default Re: Integra squeaking like a **** when idling.. help! (harrytg)
make sure the belts are not too tight or too loose and maybe oil the pulleys.
Old Apr 17, 2002 | 09:52 AM
Toby1's Avatar
One of your drive belts is too loose. Check the deflection of each belt and tighten up any loose belts. Squealing should go away. HTH.
black0hatch
Honda CR-V & Element
Sep 24, 2012 09:12 AM
Samuels
Sep 30, 2009 06:16 AM
grey_ghost
Feb 16, 2008 04:12 AM
fatalman
Apr 8, 2005 12:19 PM
harryg
May 8, 2002 10:26 AM
