integra ls turbo question
id recomend stayin w/ just an ls motor, sleeve it and boost that sucka! Ls/vtec will make more power at the samde boost levels, yet you can get the same powweer gains by adding more boost. Lots of work, endless. Once you turbo youll love the power but maintenance is critical for reliablility.
depending how easy you want to do it. boosting the ls is cheaper and easier b/c of vtec. i would say just boost the ls to get you feet in the water then build a crazy b16 head in the mena time, then bolt that mena head up to the killer ls block, get it tuned and you will be runnin like a raped aped.
