integra with h22 swap lowering problems
Old May 13, 2013 | 05:21 PM
ben h's Avatar
Default integra with h22 swap lowering problems
so i just got raceland coils atfirst i put them at the full 4 in drop just to see how it looked do i took it for a drive couldnt go over 15 felt the axles wobbling so i raised it up and kept doing it tell i was only at a 1in drop info on car is 95 rs with h22a swap has hasport motor mounts and its using stock teg axles could they just be bottoming out in the cups? or do hasport mounts make the motor sit lower and just puts that much of an angle on the cv
Old May 14, 2013 | 06:37 AM
sleepyaccord96's Avatar
Default Re: integra with h22 swap lowering problems
hasport mounts suck for a civic or teg with an h22...i have hasport axles and mounts and the design sucks. the axles shake, and the lower you go the worse it gets... Innovative and some other companies have better design..
Looks like you are in the same situation i am in. mine is lowered 2" and is ok, i got the shaking under control and what not
BTW, there is no way you have stock integra axles..they would never work. And if you did manage to put teg axles in it...then you need to remove them and put prelude inner cups and bearing on the inner joints of the teg cv axles to reduce your shaking
Old May 14, 2013 | 11:06 AM
ben h's Avatar
i bought the car like this and yea idk how but they are teg axles and any reason to put the prelude cups i know cuz there longer but thats not the problem i have i think my ales are bottoming out in the cups
Old May 14, 2013 | 12:50 PM
cmwright1986's Avatar
getting a camber kit for the front will help with the axles binding a bit
Posted from Honda-tech.com App for Android
Old May 14, 2013 | 02:12 PM
ESP.net's Avatar
ESP! Better Ground Clearance, PS compatible, Better Axle Alignment and Axle combo
Old May 14, 2013 | 03:04 PM
ben h's Avatar
hmm never thought of that
ill have to look into them
abs0Lut
Oct 20, 2011 06:54 AM
delslowcoupeB16a
Jul 1, 2006 04:39 PM
jdmcivicsi522
May 23, 2006 07:53 PM
RA217252
Jul 15, 2003 05:57 AM
