Intake manifold connectors
Hey guys. I just finished up a d series motor swap and stupidly forgot to label the connectors. There are three on the back of the intake manifold - looks like one for iac, map sensor (maybe) and then one that looks like its for evap. They all have the same connector ends. How do I figure out which goes where? Thanks
IACV (wire colors) - BLUE/YELLOW - YELLOW/BLACK (Blue circle)
IAT (wire colors) - GREEN/WHITE - RED/YELLOW (Red circle)
EVAP PURGE (wire colors) - YELLOW/BLACK - RED (Green circle)
Ignore the labels below I just googled this for reference
I think he means MAP sensor and TPS. Just for reference:
MAP (wire colors) - WHITE - GREEN/WHITE - YELLOW/RED
TPS (wire colors) - YELLOW/WHITE - RED/BLUE - GREEN/WHITE
You may need to clean your IACV
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
Ef4doorwagon
Dec 29, 2014 03:08 AM
JDMlyfestyle
12
Oct 14, 2004 08:38 PM
WannaHonda
Aug 5, 2004 01:22 PM
