Installing Zex, which TPS wire do I tap in to?
I have got pretty much everything else hooked up, but which wire on the TPS do I tap in to on my B16a? There is a red, yellow, and green...
Thanks,
jB
Thanks,
jB
i believe its the green one... im 90% sure... i just installed the ZEX kit on my b18b, so it may be different. highly unlikely though.
It's the RED one... The middle wire on the connector... When the TPS connector is clipped on the TPS the wire on the very top should be the positive, middle will be the output (then one you wanna tap into), and the one on the bottom (closest to the ground of the car) will be the negative... By the way, whenever I tap into the TPS I just do it at the ECU as it doesn't effect the engine loom in any way... If you are interested let me know what chassis you are dealing with and i'll give ya the pinout... Peace
This makes it really simple incase there are still any questions...
YELLOW = 5VDC+, RED = output (this is your TPS reference), and GREEN = gnd. Latez
dpw41285
Nov 13, 2004 12:29 AM
C4wrx
Jan 28, 2002 05:41 AM
2000, civic, crx, honda, identification, installing, instructions, integra, mustange, prelude, tap, tps, wire, wiring, zex
