installing a flywheel
Old Apr 24, 2003 | 10:06 AM
greenli0n25's Avatar
Default installing a flywheel
is there any complications to installing an aftermarket lightned flywheel or is it simple as installing any flywheel. I have not done either but i have a friend who has replaced his stock one and wanted to know if its hard or not the tranny is already seperated from the block anyway
Old Apr 24, 2003 | 10:26 AM
MikeMAN's Avatar
Default Re: installing a flywheel (greenli0n24)
if the tranny is seperated already, it should be cake..
mike
Old Apr 24, 2003 | 11:52 AM
ScottEK's Avatar
Default Re: installing a flywheel (MikeMAN)
yeah if the tranny is off it's cake, make sure you have a clutch alignment tool though. Some times after market flywheels come with hex bolts to use instead of the OEM hardware, I don't know which is better to use but personally I'd use the OEM because you can torque it to actual numbers.
Old Apr 24, 2003 | 12:32 PM
Blaze45's Avatar
Brrraaaap!
Default Re: installing a flywheel (beta13)
Be sure to get a 12pt 17mm socket for it. and a 10mm 12pt for the clutch and some lock tight.
Blaze
Old Apr 24, 2003 | 02:03 PM
cool thanks guys
sebTeggy
Sep 21, 2011 04:24 AM
big_daddy234
Sep 21, 2009 07:48 PM
DC2-ProdUcTiOnS
May 9, 2009 06:57 PM
hondadc2
Oct 12, 2008 10:02 PM
Rywire
Apr 20, 2004 03:55 PM
