installing boost gauge: Illumination wire??
Old Oct 26, 2002 | 09:15 AM
vactor's Avatar
Default installing boost gauge: Illumination wire??
ok. i am installing a boost gauge in my itr. i need to find a place to connect the illumination wire for the gauge. is there a convenient place in the fusebox to do so? i seem to remember that in the 5G civic that there was. if so, then all i would have to do is connect a spade connector to the wire and insert it into the appropriate free slot in the under-dash fuse box and voila, sanitary illumination wire installation. anyone find out if that is the case? i am currently a bit too lazy to use my DMM and go looking for it and thought maybe someone who has done this could give me the correct and convenient place to hook it up. thanks!!!
Old Oct 26, 2002 | 09:35 AM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: installing boost gauge: Illumination wire?? (vactor)
the ignition wire should be sufficient. How abuot the dimmer wires?
Old Oct 26, 2002 | 09:44 AM
vactor's Avatar
Default Re: installing boost gauge: Illumination wire?? (Nvious R)
not quite sure what you mean by "the ignition wire should be sufficient. How abuot the dimmer wires?" but i am looking for the dimmer or a lights-on connection so i cn have the boost gauge illuminate and dim with the dash lights.
Old Oct 26, 2002 | 09:47 AM
Double 06's Avatar
New User
I spliced into a dash light. Keeps the wires from showing. Have a helms to know exactly which wire, i can not remember.
Nvious R's Avatar
let me try and find out what color the wire is on the dimmer. Can you read Scematics?
Old Oct 26, 2002 | 09:56 AM
vactor's Avatar
forget it. just gonna use the free option connector #2 in the fuse box. light won't dim, but will turn on with lights and keep a factry look
MilanoLude
Mar 19, 2007 03:26 PM
tyflip2
May 26, 2004 06:53 AM
braintree
Jul 16, 2003 12:20 AM
mrlegoman
Feb 3, 2003 04:15 PM
