installing axle
Old Jun 14, 2003 | 11:20 AM
munscher's Avatar
Default installing axle
i can't get the passenger side axle to go all the way in on my 93 prelude Si.... it lines up with the splines and starts to go in, but stops shy by about 1.5 inches or so.... is this normal? you just have to keep tryin? or does this mean the circlip needs to be replaced? Any tricks to getting the axle in?
Old Jun 14, 2003 | 11:39 AM
5LuGinTeg's Avatar
Default Re: installing axle (munscher)
push it in with the other end of the axel. if not you might have the wrong axel
Old Jun 14, 2003 | 12:49 PM
Foozball26's Avatar
Default Re: installing axle (5LuGinTeg)
I have a good method its called the yank 'n push
the cv joints are floating assemblies so all you do is yank on the outer end and push it towards the car, this will bang it in.
I have done it everytime and is a snap.
Old Jun 14, 2003 | 04:37 PM
chevyalltheway's Avatar
you can try and hammer it in. just make sure you take the right precautions to not f-up the splines.
Old Jun 14, 2003 | 07:31 PM
Foozball26's Avatar
Default Re: installing axle (chevyalltheway)
no dont hammer it b/c you will mushroom the end andwill never get it in
Old Jun 15, 2003 | 06:10 AM
Prelude Vtec 23's Avatar
Default Re: installing axle (Foozball26)
It is hard to get in all the way bcuz of the snap ring on it. What I have done many times to get axels in is make sure you have it aligned PERFECTLY straight from underneath the car and have a friend use a rubber mallet lightly hammer it in. When you hammer it if it does not go in it is bcuz it is not perfectly straight and lined up properly. Once it is it will go right in, you just need to get past that snap ring.
rgarrett
Transmission & Drivetrain
Oct 5, 2017 04:57 AM
Tim2179
Mar 27, 2008 12:25 PM
civcexcoupeblack
Sep 20, 2002 10:04 PM
drumsy
Jul 3, 2002 04:33 PM
Aron Parsons
Apr 15, 2002 01:17 PM
