Installed new ECU, vtec is glithy....
Old Dec 16, 2003 | 07:17 PM
PolySquared's Avatar
Default Installed new ECU, vtec is glithy....
I just replaced my ecu with a programmed obd1. My vtec kicks about 6000rpm, if i run it hard, it gets very glitchy. Is it badly tuned? do i need more fuel?
Old Dec 16, 2003 | 08:03 PM
HRTuning's Avatar
Default Re: Installed new ECU, vtec is glithy.... (PolySquared)
What's the setup and what program did you choose?
Old Dec 16, 2003 | 11:52 PM
iH8RICERZ's Avatar
Default Re: Installed new ECU, vtec is glithy.... (HardLowrdRanger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HardLowrdRanger &raquo;</TD></TR><TR><TD CLASS="quote">What's the setup and what program did you choose?</TD></TR></TABLE>
ditto.........sounds like the program.........pm me, i can try to help you figure out what it is...also, did you chip your ecu yourself?
Old Dec 17, 2003 | 05:14 AM
youngvedder's Avatar
Default Re: Installed new ECU, vtec is glithy.... (iH8RICERZ)
I had that problem, where vtec would kinda studder at engagement after and obd I was installed. for me, it was my timing was a bit messed. I corrected that and the issue was gone.
Old Dec 17, 2003 | 06:53 AM
hispanic panic's Avatar
We need more fuel scotty!
Old Dec 17, 2003 | 07:25 AM
Dan GSR's Avatar
Default Re: (hispanic panic)
also check your oil level
Old Dec 17, 2003 | 12:32 PM
Default Re: (Dan GSR)
i just checked my oil leve and its fine. When you said timing, do you mean the timing belt? I think my program is "prospeed". Vtec starts at 6000k and redlines at 8500.
blacktibby07
Jun 8, 2011 07:11 AM
turboteg90
27
Jun 20, 2008 01:46 PM
dylokjai
Apr 25, 2007 05:22 AM
moosepoop21
Aug 29, 2006 05:39 AM
chiefvtec
Feb 4, 2003 06:04 PM
