injectors wont fire need help
i have a obd0 civic converted to obd1 with a boomslang conversion harness and ive got spark and fuel to the injectors but the inj. are not firing ive tested everything back to the ecu and i have continuity and all the wiring is correct. we have had this problem before but only on interga da's we anded up using a ry wire harness then everything worked perfect, the boomslang harnesses have always worked on civic's wtf.
ef8sleepr
Feb 23, 2006 09:25 PM
put a rywire harness in fired right up!
