Injectors Not Working HELP
Old Jul 3, 2004 | 09:08 PM
turboex's Avatar
Default Injectors Not Working HELP
Spun bearing in b16a, Engine ran fine with exception of bearing knock into garage. Swapped Crank reassembled and now engine will not start. Getting Spark, tripple Checked timing. Checked plugs and they were dry. Checked and no voltage going to Injectors. Checked ECU fuse *good*. Since Battery was dissconnected Rechecked all APexi VAFC Settings Reinitalized and setup 6in 6out. /. But still nothing. Its about 3am Eastern and I'm exhausted. WIll give it a fresh start in the morning. Anyone have any ideas of what would cause the injectors to not fire? Or any other ideas? Thanks
Old Jul 3, 2004 | 09:26 PM
PHiZ's Avatar
Default Re: Injectors Not Working HELP (turboex)
Check the ground on the thermostat housing, it should not be on the starter...
-PHiZ
Old Jul 4, 2004 | 05:30 AM
turboex's Avatar
Default Re: Injectors Not Working HELP (PHiZ)
Ok time for a fresh start. Thanks Phiz, Checked ground on housing lastnite, but double checked today and its securly attached. Still no power to injectors. No Check engine light either.
-TurboEX
Old Jul 4, 2004 | 09:15 AM
PHiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboex &raquo;</TD></TR><TR><TD CLASS="quote">Ok time for a fresh start. Thanks Phiz, Checked ground on housing lastnite, but double checked today and its securly attached. Still no power to injectors. No Check engine light either.
-TurboEX</TD></TR></TABLE>
Which side isn't getting voltage? the yel/blk 12v wire? Or the ecu wire? Ecu drops to ground to make injector fire, so still, could be a bad ground.
Fuel pump clicking on?
-PHiZ
Old Jul 4, 2004 | 03:23 PM
HamiltonRex's Avatar
I have a similar problem.
My main relay is buzzing, and when i disconnect the injector harness, it stops. They blue/yellow wire that goes right though the harness that has 12v when the ignition is on is the wire that is making it do that.
Whats that wire do?
All my grounds are good, i get continuity at the big black wire on the distributor harness, so im thinking is linked to some sensor malfunctioning.
please help!
Old Jul 4, 2004 | 03:29 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboex &raquo;</TD></TR><TR><TD CLASS="quote"> Still no power to injectors. No Check engine light either.
No cel at all? When you turn the key on it should come on for 2 seconds and then go off . Check your fuses.
Old Jul 4, 2004 | 03:38 PM
Default Re: Injectors Not Working HELP (Chiovnidca)
any help for my problem?
Old Jul 19, 2004 | 03:47 PM
1RMDave's Avatar
Default Re: Injectors Not Working HELP (HamiltonRex)
I'm having the same problem.
Old Jul 20, 2004 | 05:11 AM
JimBlake's Avatar
Default Re: Injectors Not Working HELP (1RMDave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1RMDave &raquo;</TD></TR><TR><TD CLASS="quote">I'm having the same problem.</TD></TR></TABLE>Which problem?
Injectors not firing, or have you narrowed it down to one or the other side of their circuit? CEL or not??
anon191
17
Jun 25, 2013 10:33 AM
castle1313
May 21, 2009 08:43 AM
KrispyKreme
Jan 4, 2006 08:39 PM
Trac226
Jul 23, 2003 12:30 PM
