Injectors arn't fireing?!?!?!?!?!
Old Mar 15, 2003 | 06:00 AM
cr-x si's Avatar
Default Injectors arn't fireing?!?!?!?!?!
Ok i finished putting in my zc yesterday, it is all wired up good. It will turn over strong but won't start. It has good spark and strong compression. For some reson the injectors arn't fireing. I have at 89 integra ecu (pg7) and my si ecu (pm6) when the teg ecu is in the light goes crazy i can't even read it. it never pauses it just stays on. When i put my si ecu on, the is no light at all. Why arn't my injectors fireing? I have real strong fuel pressure.
When we sprayed a little engine starter in the throtle body it fired right up. But then died. Do you guys have any suggestions.
I want to get it running today.
Old Mar 15, 2003 | 08:38 AM
cr-x si's Avatar
Default Re: Injectors arn't fireing?!?!?!?!?! (cr-x si)
bump
Old Mar 15, 2003 | 08:43 AM
matt_sb2000's Avatar
Do you have the crank angle sensor hooked up right?
Old Mar 15, 2003 | 08:46 AM
cr-x si's Avatar
Default Re: Injectors arn't fireing?!?!?!?!?! (matt_sb2000)
i thing so. isn't it just a plug?
Old Mar 15, 2003 | 08:51 AM
Do you have power at the resistor box for the injectors?
Old Mar 15, 2003 | 08:54 AM
cr-x si's Avatar
is that the little silver metal box at the top left corner of the engine bay. It should be working as far as i know. everything was working fine when i pulled out the a6
Old Mar 15, 2003 | 08:55 AM
Make sure that there is +12v on the yellow wire there at the resistor box.
Old Mar 15, 2003 | 08:59 AM
cr-x si's Avatar
ok i will check
Old Mar 18, 2003 | 01:50 PM
fathergoose's Avatar
do a balance test youll see if the problem comes from your injectors
Old Mar 18, 2003 | 03:57 PM
19924ws's Avatar
Default Re: Injectors arn't fireing?!?!?!?!?! (fathergoose)
Make sure that ALL the grounds are connected. There is aground just for the injectors on the Preludes and if they are not connected then you've got nothing. Mike
anon191
17
Jun 25, 2013 10:33 AM
sohcEKturbo
Feb 17, 2009 06:39 PM
cr-x si
Mar 15, 2003 03:13 PM
civbeater90
Nov 23, 2002 09:37 PM
civbeater90
Nov 22, 2002 06:35 PM
