Injectors???
Is there a difference between saturated and peak/hold injectors???
Is it true that saturated is for N/A and peak/hold is for FI???
Im turbo and wanna go up to 550cc, which would i buy???
Can someone give me some info???
yes there is major difference between peak nad hold and saturated.
the major difference is within the ohm its takes to fire the coil within the injector. All an injector is a coil.
The coil in saturatd usually in the range of 14-16ohms while the peak and hold is 2-4ohms
honda stock ecu is based on a saturated driver.
If you can get 550cc saturated then that will be plug and play with a good chip tune.
no that is incorrect you need saturated not peak and hold peak and hold is 2ohm-4ohm will not work unless you have resistor box or some injector driver.
