Injector Sizing
Old Feb 25, 2006 | 06:55 AM
TifosiLou's Avatar
Default Injector Sizing
I have 1990 CRXsi with a D16A6 which I race at a local road course. The engine is stock with only a header and advanced cam timing. I want to upgrade the power (no I don't want a turbo). I have ordered a slightly hotter cam, an OBX intake, cam timing gear, and want to add a larger throttle body, new valve springs and retainers, do a mild port job and add a Hondata ECU. I guess I need to increase the injector size, but to what? I believe the stock is 235cc. If I jump to say a 270cc, how long will that hold me? Do I have to then get another set of yet larger injectors at each performance increase? Or can I jump to a larger size now in anticipation of future adds and power? Any help appreciated.
Old Feb 25, 2006 | 07:44 AM
drdisco69's Avatar
Default Re: Injector Sizing (TifosiLou)
Raising the fuel pressure would help with the injectors you have now, and 270s will be plenty for a little allmotor D16. You shouldn't need more than that.
Oh, and welcome to Honda-Tech.
Old Feb 25, 2006 | 07:38 PM
TifosiLou's Avatar
Default Re: Injector Sizing (drdisco69)
Thanks for the welcome, seems like a good forum. How do I raise the fuel pressure? And to what? Should I add a guage? Thanks.
Old Feb 26, 2006 | 06:29 AM
drdisco69's Avatar
There are many adjustable aftermarket fuel pressure regulators. B&M is cheap, takes some modifying the stock regulator to put on though. The more expensive ones replace the regulator, but you pay for the convenience. A gauge is a must, otherwise you're shooting in the dark.
The stock fuel pressure is 38psi. Raising it to 50 will make the stock 240cc injectors act like 257cc injectors, which is plenty.
jceltalentoso
K Series
Mar 13, 2014 03:30 PM
sleeper_92
Apr 21, 2013 07:45 AM
JayJay2912
Jun 16, 2010 08:24 AM
Neutex22
Jan 15, 2005 09:39 AM
Sinner
Dec 23, 2003 07:09 PM
