Injector question
im using a '00 intake manifold on my 91 civic si block..
i already know i cant use the 2000 injectors so i will be using my 91 injectors, my question is::: which injector to manifold/fuel rail o-rings/seals do i use?
i havent taken the injectors out of my 91 yet because im still driving it so i cant hold them up and check them.
thanks in advance
thanks in advance
Im not so sure how important it is until you get there. Itll be one or the other. I would use the o-rings that come with the manifold and just stick you old injectors into all the new rail and manifold.
im going from SOHC to SOHC.. i looked on a parts site and the sizes are the same for the o-rings so i just ordered the newer style to use with my old injectors. woop
