Injector leakingin cold
When I start my car on a clod day my 3rd fule injector is wet and the whole car smells like gas. Is this a common problem? What should I do to fix it? Is there a seal or something that needs to be changed.
yes, there are some seals that you can replace. check this picture out: http://www.acuraautomotiveparts.net/...NIFOLD+%281%29
when i pulled my injectors they started leaking because one set of the o-rings were very worn out (all of them broke when i removed them for replacement). The o-rings that were bad on my injectors are #14 in that picutre. Parts #2 and #3 were fine in my situation.
trbob16a
Apr 17, 2003 12:41 PM
EGh22aEG
Mar 29, 2002 04:11 PM
