injector?
ok guys im doin an h23 to h22 swap in a prelude and i kept reading that the injectors can be swapped (ie using the same plugs) but i couldnt get mine to work so i get to lookin and on the h22 harness the injector plugs have been changed so i pulled the injector out and the only markings on it are "kei hin" on one side of the upper plastic 4 dots on the other side with 6 P D C in the center and PD28 stamped on the lower metal part, any idea what these are from and can they safely be used on an h22, obdI by the way, or do i have to change the resistor pack.
Modified by noble4ws at 1:31 AM 10/30/2003
