individual coils
Old Mar 16, 2005 | 11:26 AM
  #26
85's Avatar
85
Default Re: (3RdT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3RdT &raquo;</TD></TR><TR><TD CLASS="quote"> suby's have coils like that. r there any cons in doing this?</TD></TR></TABLE>
everyone has coil setps like that. my first car back when i was in 10th grade a 98' Suzuki Sidekick had that setup. the funny thing was, it said Mitsubishi all over it lol
Old Mar 16, 2005 | 01:48 PM
  #27
D-tuned's Avatar
Default Re: (machine4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">forgot to ask about the wirring for the coil on plgus ,2000si
im assuming that of the 3 wires one is a chassi ground and assuming that one would be positve from the CDI and what woudl the other be for ?
thanks for the help </TD></TR></TABLE>
there is allot wiring than that. when you buy the c2di it has a diagram in it. you have to wire 4 coil outputs of the ecu to the 4 coil inputs on the c2di. the wire the 4 coil outputs from the c2di to the 4 coils. the c2di has 2 540V outputs. one of those outputs goes to coil 1 and 3. the other goes to 2 and 4. you have to run 2 wires to the battery( one positive and one negative). plus 2 switched 12v sources. thats all the wiring for direct firing if you standalone has 4 coil outputs. if your standalone has 2 coil outputs then you can run waste spark and the wiring is different. then program your ems so it knows when to fire the coils.
Old Mar 16, 2005 | 02:44 PM
  #28
machine4321's Avatar
is there only one ecu out pu tor is there 4? i would have though there is only one in the s\dizzy since it would delagate where the spark was going ..then i thought the cdi would do the same thing
as far as the other wiring goes i already acounted for all that stuff..
so coils have a positive and negitive and a trigger wire ..makes sence
also do you know how long the coil on plugs are ...trying to find some that fit the h22 head ..thanks again any more info you have would be great
cant thank you enough
Old Mar 16, 2005 | 02:46 PM
  #29
you have EMS
im talking about stock chipped ecu...dam i hope this is possible
Old Mar 16, 2005 | 06:58 PM
  #30
D-tuned's Avatar
you can not do its with a stock or chipped ecu. you need a standalone to do a cop conversion. the stock ecu only have one coil output.
Old Mar 16, 2005 | 07:45 PM
  #31
worst news EVER lol ..that sucks
but again thanks for your help
mabye one day i can afford it
wellssc2002
11
Feb 2, 2016 02:46 PM
motoxxxman
May 1, 2015 09:00 AM
JDM_EK4_Coupe
Apr 10, 2007 06:05 AM
swsupermini.com
Feb 6, 2006 05:16 PM
k_spec
May 31, 2005 10:31 PM
