I'M HAVING IGNITION PROBLEMS! PLEASE HELP!!!
Old Feb 15, 2005 | 05:41 PM
whojoedaddy's Avatar
Default I'M HAVING IGNITION PROBLEMS! PLEASE HELP!!!
in the morning, i would start my car then it would stall, then i start it up again and it would stall...after about 15-20 times doing this, it will stay started...what is the problem?...at first i figure it was electrical, so i got new ignition module, spark wires, new spark plus, distributor cap and rotar...any help is greatly appreciated.
Old Feb 15, 2005 | 06:29 PM
Redline130's Avatar
Default Re: I'M HAVING IGNITION PROBLEMS! PLEASE HELP!!! (whojoedaddy)
Is the check engine light on? Any codes from the ecu? Did changing all those parts help your situation?
Old Feb 15, 2005 | 06:30 PM
Default Re: I'M HAVING IGNITION PROBLEMS! PLEASE HELP!!! (Redline130)
94 accord lx 2dr...nope those parts did not help...the check engine light is not on either
mmuller's Avatar
Mad Scientist
describe how it dies better; does ot just stall, slowly dies, stalls because of low idling?
Old Feb 15, 2005 | 06:31 PM
Default Re: I'M HAVING IGNITION PROBLEMS! PLEASE HELP!!! (mmuller)
it just dies, then i have to start it again...
i can't post anymore, so i'm editing this one
i will give it gas and it will stay started longer, but then the rpm gauge meter will jump and then die again
Modified by whojoedaddy at 8:05 PM 2/15/2005
Old Feb 15, 2005 | 06:32 PM
mmuller's Avatar
Mad Scientist
does it stall even if you give it gas?
Old Feb 15, 2005 | 11:03 PM
HmgLauj69's Avatar
my car started doing this too...most likely dirty injectors or the main fuel relay
Old Feb 16, 2005 | 06:16 PM
mmuller's Avatar
Mad Scientist
Default Re: I'M HAVING IGNITION PROBLEMS! PLEASE HELP!!! (HmgLauj69)
check your ignitor; check all connections inside the dizzy
Old Feb 16, 2005 | 08:09 PM
jerseybrandon's Avatar
Second on the ignitor.
Old Feb 16, 2005 | 10:15 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">check your ignitor; check all connections inside the dizzy</TD></TR></TABLE>
rodriguez
May 24, 2008 05:26 PM
fcfromhell420
Nov 3, 2007 08:22 PM
bullwinkle777
Jul 21, 2007 06:18 PM
whojoedaddy
Feb 15, 2005 06:40 PM
FuzzyGreen
Nov 8, 2001 04:02 PM
