Ignition timing on a d16z6...HELP
Old May 15, 2003 | 04:20 PM
pg_thao's Avatar
Default Ignition timing on a d16z6...HELP
when i put the timing light on my motor, at idle its at the tdc mark.. and at 3k its at the last line on the pulley.. does that sound right..
also which line is the stock one??
Old May 15, 2003 | 07:47 PM
Chiovnidca's Avatar
Default Re: Ignition timing on a d16z6...HELP (pg_thao)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pg_thao &raquo;</TD></TR><TR><TD CLASS="quote">when i put the timing light on my motor, at idle its at the tdc mark.. and at 3k its at the last line on the pulley.. does that sound right..
also which line is the stock one??</TD></TR></TABLE>
Warm the engine up completely, make sure the idle speed is properly set, jump the service check connector and set the timing to the center red mark. (For stock timing.)
92ehatch
Jul 28, 2007 05:40 PM
importlegions
11
Apr 14, 2005 06:13 PM
kihun_cha
Sep 20, 2004 09:32 AM
slowd16z6
Mar 13, 2004 02:20 PM
EF-21
Feb 20, 2004 09:18 PM
