Ignition system question
Old Feb 2, 2006 | 08:14 AM
baggelis's Avatar
Default Ignition system question
I receintly acquired a 91 hatch Si, it ran fine for a while, it actually came all the way from New Hampshire to Florida with no problems. A couple of weeks ago the car wouldn't start, I checked for spark at there was none. I replaced distributor cap and rotor and nothing, so I went ahead and replaced the distributor. Now it is running fine. I noticed that the old distributor had a burned part and I am wondering if there is something else that I need to change that might be causing the distributor to fail.
I was told by a mechanic that probably my main relay is bad, do you guys think that is correct???
Feedback is greatly appreciated
Old Feb 2, 2006 | 12:37 PM
Perfectionist's Avatar
Default Re: Ignition system question (baggelis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baggelis &raquo;</TD></TR><TR><TD CLASS="quote">I noticed that the old distributor had a burned part and I am wondering if there is something else that I need to change that might be causing the distributor to fail.
Which 'part' was burned? Could be normal discoloration.
The main relay provides power to the fuel pump and fuel injectors. I don't see how it could kill a distributor.
An open plug wire, bad spark plug, or cap/rotor could make it hard on the distributor. The spark has to go somewhere and will take the path of least resistance to ground.
Old Feb 2, 2006 | 01:11 PM
baggelis's Avatar
Default Re: Ignition system question (Perfectionist)
I am refering to the part where the distributor cap pin is inserted.
Thank you
DRAGANDB1
Aug 9, 2018 06:19 PM
aTrOcIoUs
Aug 3, 2007 02:54 PM
asiansgoweeee
17
Nov 12, 2004 07:20 PM
SI_niki
Jun 15, 2004 07:54 AM
IntegD
Apr 2, 2004 10:16 AM
