Ignition Coil Wiring
Old Jul 27, 2004 | 11:49 AM
PERFDIST's Avatar
Default Ignition Coil Wiring
On an externally mounted stock coil, the coil has a 4 pin connector attached to it.
My Haynes manual labels these A, B, C, and D, but it does not identify where each letter goes. It appears that A and B both have a black wire with yellow stripes. C and D both have a blue wire with red stripes.
Can someone identify these?
Thank-you!
Old Jul 27, 2004 | 11:57 AM
chad's Avatar
Moderator
Default Re: Ignition Coil Wiring (PERFDIST)
i presume this is for a honda....but??? need to know which hUnda
Old Jul 27, 2004 | 12:13 PM
PERFDIST's Avatar
Default Re: Ignition Coil Wiring (chad)
'92 Acura-Integra 1.6L.
Has an external coil.
Thanks!
Old Jul 27, 2004 | 04:13 PM
chad's Avatar
Moderator
what brand external coil?
i take the white wire(has a tracer on it i think...dont' remember) from stock COIL and run it to the NEG. on the external coil....
then the black with yellow stripes to positive.....
deftones0817
Jun 20, 2005 06:59 AM
