ignition advance rules of thumb
Old Oct 5, 2001 | 06:05 AM
SOHCArchangel's Avatar
Default ignition advance rules of thumb
is there a table somewhere that shows detonation degree threashold per cr(compression ratio) and ambient intake temp per fuel grade at given load points? TIA
Old Oct 5, 2001 | 07:13 AM
VTEC4GS's Avatar
Default Re: ignition advance rules of thumb (SOHCkordVTEC)
Its actually not that simple since there is no "standard" since there are too many variables which can make a specific combination more efficient than others. Many people talk about 12.5:1 compression ratio and its vulnerability to ping when using pump gas, etc.... honestly thats jsut a myth because, there is a lot more going on when the cams are degreed and the motor is tuned via camgears. The overlap actually reduces the cylinder pressure that everyone is so scared of. Second, the valve deshrouding, quench shape, deburring material inside chambers, exhaust combination, etc. all play such a big role that its not a simple answer.
Greg
Old Oct 5, 2001 | 10:58 AM
Default Re: ignition advance rules of thumb (vtec4gs)
oh ok, well my cr is not that high (8.8:1) and have advanced it considerably, i just wanted to do some reaserch before i advance some more
Old Oct 5, 2001 | 11:56 AM
mercury's Avatar
New User
Go with your good ear or a J&S Safeguard...
allmotorpackage
17
Apr 19, 2013 03:24 PM
josh's ep3
Dec 24, 2010 07:50 AM
DCFIVER
19
Sep 30, 2008 05:47 PM
M SPEC
Jan 14, 2003 12:08 PM
BigMoose
Jul 23, 2002 10:52 PM
