If some negative camber is good for handling, why...
Old Jul 4, 2003 | 01:10 PM
2003 VTEC's Avatar
Default If some negative camber is good for handling, why...
Why did my '03 V6 Accord come from the factory with between 0° to +0.2° camber in the front, and between +0.5° to +0.7° camber in the rear? Far as I can tell, those are real close to being correct facory specs. Seems to me if I lower it about 1.5" I'll then have a little negative, which should be a good thing, right?
Old Jul 4, 2003 | 01:22 PM
xteg95's Avatar
Default Re: If some negative camber is good for handling, why... (2003 VTEC)
wouldnt you be doing a lot more wear on your tires then?
Old Jul 4, 2003 | 04:54 PM
Chiovnidca's Avatar
Here are Hondas recomended specs:
Camber
Front 0º00'+/-45'
Rear -1º00'+/-30'
Caster
Front 3º15'+/-45'
Total Toe
Front 0+/-2 mm (0+/-1/16 in.)
Rear IN 2+/-2 mm (1/16+/-1/16 in.)
00IntegrAllmotoR
Aug 12, 2009 06:48 PM
bopbop93030
Suspension & Brakes
Apr 8, 2008 04:08 PM
bopbop93030
Apr 6, 2008 08:32 AM
nichols_si
Oct 2, 2003 12:03 PM
Andrew 825SM
Aug 15, 2003 03:16 AM
