if header is missing a bolt, will this cause vacum leak?
Old Jun 3, 2003 | 09:52 PM
airborne84000's Avatar
Default if header is missing a bolt, will this cause vacum leak?
as i asked, one if the bolts that holds header on the head is stripped. will this cause a major vacum leak??? I am having very bad idel problems and car runs like **** like its rich or something. it boggs. I just had it dyno tuned 2 weeks ago so I know fuel mixture is correct. what do you guys think?? is it just a vacum leak????
thanks in advance
Old Jun 3, 2003 | 10:52 PM
bearingburner's Avatar
Default Re: if header is missing a bolt, will this cause vacum leak? (airborne84000)
possible. it may trick your o2 sensor in thinking/reading lean and forcing the ecu to richen the mixture. idle it should not effect much at all. that may be an entire different problem.
Foozball26's Avatar
all the header does is collect the the exhaust gases it has nothing to do with vacuum.
Old Jun 3, 2003 | 10:53 PM
Foozball26's Avatar
Default Re: if header is missing a bolt, will this cause vacum leak? (foozball-26)
also, you have like 9 other bolts or studs/nuts hold the header on so worst thing i could do is cause an exhaust leak.
Old Jun 4, 2003 | 03:03 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by airborne84000 &raquo;</TD></TR><TR><TD CLASS="quote">as i asked, one if the bolts that holds header on the head is stripped. will this cause a major vacum leak??? I am having very bad idel problems and car runs like **** like its rich or something. it boggs. I just had it dyno tuned 2 weeks ago so I know fuel mixture is correct. what do you guys think?? is it just a vacum leak????
thanks in advance</TD></TR></TABLE>
If it has an exhaust leak there, it can also let air in which will screw up your o2 sensor voltage. (It would make it run rich.)
Old Jun 4, 2003 | 03:23 AM
Foozball26's Avatar
Default Re: if header is missing a bolt, will this cause vacum leak? (Chiovnidca)
no the exhaust will leak OUT constant pressure coming out won't let air go in.
besides the other bolts on the manifold would hold it tight enough to the head you shouldn't even get the leak.
Old Jun 4, 2003 | 09:25 AM
ok thanks guys, I just took it over to the shop today to be looked at. I'll let you know what happens
Old Jun 4, 2003 | 09:34 AM
1_bad_EF's Avatar
no it wont. Unless you only have like 3 bolts holding it on, maybe. But that is why you have a Exhaust Manifold Gasket. Also it wouldnt be a vaccum leak if it was in the exhaust. It would be an exhaust leak, and prolly would blow out instead of suck fresh air in. Check the intake side for vacuum leaks and all wiring to sensors, eg O2, map,
Old Jun 4, 2003 | 10:04 AM
blah13's Avatar
Default Re: if header is missing a bolt, will this cause vacum leak? (1_bad_EF)
You can take out that stripped bolt, vice grips it and it will come out. I had one that was messed up too so I just replaced it, only about $1.
Old Jun 4, 2003 | 01:53 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foozball-26 &raquo;</TD></TR><TR><TD CLASS="quote">no the exhaust will leak OUT constant pressure coming out won't let air go in.
Wrong. A leak in the exaust system will let air in also. If the leak is upstream of the o2 sensor, it will throw off the reading.
Old Jun 4, 2003 | 03:53 PM
Foozball26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Wrong. A leak in the exaust system will let air in also. If the leak is upstream of the o2 sensor, it will throw off the reading. </TD></TR></TABLE>
dude its common sense try blowing in a straw constantly, air is not going to be let in while you are blowing out of the straw, same goes for the exhaust manifold b/c of the constant pressure comming out of the head.
use your noodle
Old Jun 4, 2003 | 04:10 PM
ThrillaKilla's Avatar
use your noodle</TD></TR></TABLE>
makes a lot more sense to me....
Old Jun 5, 2003 | 03:07 AM
Chiovnidca's Avatar
Default Re: if header is missing a bolt, will this cause vacum leak? (Foozball26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foozball26 &raquo;</TD></TR><TR><TD CLASS="quote">
That would make sense, if it were true. but there isn't constant presure coming out of the head. It comes out in pulses. Think about it.
Old Jun 5, 2003 | 04:12 AM
EE_Chris's Avatar
As air flows over a hole that is perpendicular to the flow, vacuum is created.
A simple example: Drag racers using the exhaust to DRAW out crankcase fumes.
Old Jun 5, 2003 | 08:02 AM
raene's Avatar
That would make sense, if it were true. but there isn't constant presure coming out of the head. It comes out in pulses. Think about it. </TD></TR></TABLE>
This is right..
It's the same idea with why a lot of cars use AIR systems to inject fresh air into the exhaust manifold, to prevent exhaust reversion, getting exhaust gas sucked back into the head... it confuses the O2 sensor when this happens. Injecting air with an AIR system prevents this reversion.
Old Jun 5, 2003 | 09:52 AM
1_bad_EF's Avatar
Default Re: if header is missing a bolt, will this cause vacum leak? (raene)
Is the new thing to run no exhaust manifold gasket??????????????
Old Jun 5, 2003 | 12:51 PM
Foozball26's Avatar
right it pulses look at the firing order 1-3-4-2 so there would always be a cyl. ejecting gases so it fills up the spaces in between each cyl. pulses
that theory would be true if all the cyl fired at the same time
theres still no way for air to get in though b/c he is only missing one bolt.
Shonn
Aug 31, 2006 06:11 AM
EJ1 wilcox
10
Apr 27, 2004 09:52 AM
Project_ED8
Mar 10, 2004 11:36 AM
ebelp
Jul 29, 2003 10:21 AM
geminis2k
Mar 3, 2003 02:45 PM
