IDOL problem...need help!!!!!!!!!
Old Oct 8, 2008 | 09:22 PM
da9kid11's Avatar
Default IDOL problem...need help!!!!!!!!!
hey i gotta a 93 civic coupe wit a d15b. some times when my car is warm the idol jumps up and down from 500rmp-1500rpm. any one know what is causing this? and will i do damage to my motor if not fixed?
Old Oct 8, 2008 | 09:51 PM
89s1's Avatar
Default Re: IDOL problem...need help!!!!!!!!! (da9kid11)
It is spelled "Idle"
Search for "Idle surge" and you'll get the info you need.
you will need to clean the IACV or bleed the cooling system, or adjust the FITV. depending on which one it is and what type of intake manifold you've got.
Old Oct 9, 2008 | 01:38 PM
srmofo's Avatar
Default Re: IDOL problem...need help!!!!!!!!! (89s1)
I bet you didnt find **** when you searched for IDOL wtf A vaccum leak can also cause that, but thats sypmtom is usually at all temps not just when it is warm
Old Oct 9, 2008 | 07:36 PM
i-Touge Eg6's Avatar
check your tps, vaccum lines, map sensor, take your intake off to check your fitv and iacv. let it idle and cover one hole up, then the other.
Justinmnhall
22
Sep 6, 2013 03:40 PM
bads2k
Feb 2, 2010 10:07 AM
RiceBurninCX
Jan 24, 2008 02:02 PM
jboogiebrown
Feb 18, 2006 02:35 AM
Teknic73
Dec 1, 2003 08:44 PM
